Need Location of Gas Tank Pick Up
Dinows
I am trying to get some water out of my tank on my 25 Wellcraft Sportsman, I want to tilt the boat to a position that would be most advantage for pumping out the tank. would anyone know where to pick up tube is located ?
Thanks in advance
Bt Doctur
usually toward the rear of the tank, follow the fuel hose from the engine
Dinows
OK Thanks, problem is I cant get at where the tube goes without major surgery
bruceb58
Hard to imagine they don't have an access port right above the fuel sender. My Wellcraft does.
