Need more top end from 1994 Yamaha 200
IIIKings
I have a '94 Aquasport 21' center console. It's a little over 3k lbs. I can only cruise at about 25-26 mph at 4200-4400 rpms. I can only get to 5300 and barely 5400 rpms when I have it wide open and trimmed just before porpoising. At this point I can only take her to 36 mph. I don't think it's out of the question to get her to 5500 rpms and hope for at least 45 mph top end??? I currently have a 15 1/4 x 19 prop on her. I've tried a 17 x 17 prop, becasue I had access to one...gave me too high RPM but only 2 more mph. The Yamaha specs call for a 15 3/4 x 17. I'll try that next. This winter I plan on adding a jack plate since the boat has an Armstrong bracket. Because of this the motor sits very low in the water. I've had it at the highest hole and it cavitated. I now have it back to the lowest hole the guy I bought it from had it. The motor is in very good condition, everything checks out.
After I do the prop and jack plate, is there anything I can do to the motor itself to soup it up?
Thanks
Matt
IIIKings
Re: Need more top end from 1994 Yamaha 200
If there are replies, could you mention which aftermarkets would be the best to beef up the motor?
Thanks,
Matt
Ray Neudecker
There are more horses there. 225 carbs and heads as well as the exhaust divider well pick it up with bolt ons. I wold not reccomend going beyond that for your application.
