need non oil fuel pump Number !
JJB
I need the model number for a non oil fuel pump for a 2000 175 Johnson to replace my vro pump and also VAPOR SEPARATOR and vapor PUMP ASSY rebuild Kit if anyone knows the numbers . I could not find them on the BRP site . Thanks
ezeke
Re: need non oil fuel pump Number !
"No Oil" Vro Replacement Pump Kit (for Using Oil/gas Pre-mix In Fuel Tank) is Part #5007422​
JJB
Thanks , does anyone know if there a kit to rebuild VAPOR SEPARATOR and its Number ?
ezeke
I'd send a e-mail to Bill Kelly at maxrules .com. If anyone will have the kit or know where get it, he will.
Chris1956
JJB - Check Crowleymarine.com for the exploded parts lists for that motor. You should find a vapor pump repair kit, as well as a fuel pump repair kit. Why are you disconecting the oil injection?
JJB
Hey thanks for the help , I needs to be replaced and was going to save a few bucks , before I put this motor on I had been pre mixing for 15 yrs, figure one less thing to keep a check on .
