Re: need opinion on johnson 70HP
If you're in the K.C. area, corrosion isn't an issue, but waterpump maintenance, regular decarbs, oil type used (engine and L/U lube), was the engine properly winterized for storage,....these are the questions at hand that could affect the longevity of the engine.<br />Fuel system and how clean it is kept is an issue with the tripples, and as long as stabilizer has been used for storage, it "should" be ok....
