I have a 1998 Johnson 200 with a blown powerhead. The damage is extensive and a Dealer has a 2003 225 Evinrude Ficht that appears to be about the same price as what it would cost me to replace the powerhead.
He gave me a printout of the data from the engines computer however, I can only tell the obvious items.
Engine hours 452
65% of the time was between 500-1000 rpm
13% @ 1000-1500 rpm
7% @ 4500-5000 rpm
the rest at various other speeds, none over 6500 rpm
Compression Values
#1- 115 lb, 2-125 lb, 3- 120 lb, 4- 115 lb, 5- 117 lb, 6- 115 lb.
Highest Temperature achieved 158-175 2.7%, 140- 157 54%, 122-139 21%.
No Stored Current or Hard Faults.
Recurring Faults:
Code Times Last (Hrs) Description
25 11 223 EMM Temp above expected range
22 3 110 Overheat switch closed
43 1 110 Engine temp above expected range
48 5 169 Air temp below expected range
47 4 169 Air temp sensor fault
16 1 449 Intermittent loss of sync detected.
The Dealer said the engine was traded in with a bad stator and the guy wanted to upgrade. This was one engine from a set of twins, saltwater use.
I have all 3 pages of the computer print out but the forum will not allow a posting of a file that large.
Any opinions on this?
I would be thankful for any help.
Engine hours 452
13% @ 1000-1500 rpm
7% @ 4500-5000 rpm
Compression Values
Recurring Faults:
