Need orifice plug part #
I recently ordered a float chamber assembly from iboats for my 1989 Johnson 110 model j110TLAEM upon receiving it I found out the two high speed jets required the #8-32 thread instead of the stock 1/4 -20 thread that came in the original bowl I cannot figure out witch part # to order any help would be greatly appreciated thanks
Post pictures of these bowls.---And are you sure that there is a high speed jet with an 8-32 thread ??-----All I have seen are 1/4-20 on these V-4 motors.
jbcurt00
I have email them twice with no response
The open forum in the outboard engine sub-forum isnt the best place for this.
Moved to the Forum Problems and concerns sub-forum
@iboats_tim
@iboats_help
Iboats supplies the parts bit doesnt make or bundle the assembly sets. It might take some research on their end to figure out if you got the wrong parts, the set has the wrong parts or if as Racer1 notes, there arent any 8-32 jets in the motor as originally built.
Its a nearly 30yr old motor. A previous owner may have made some non-factory spec changes......
I've notified cust serv you need help.
I will post pics when I get home but the info I stated about the threads And sizes was from the instructions that came with the float chamber I ordered stating I would need to order new orifice plugs for the kit I received that the originals would not fit the originals were plastic bowls the new one I received is casted aluminum
jbcurt00
Call the CS # GA posted. Pix are great, but you really need to talk to the iboats cust serv dept not the forum
boobie
It's not the main jets you need to change. It's the intermediate ones.
