need part numbers for fuel line and more
badbowtie
I remeber a couple years ago there was a site I could look up diagrams and it had numbers you scrolled down and it gave you the part numbers. Like I need a part number for the metal fuel line that goes from the fuel pump up to the quadra jet carb on a 85 mercrusier 260hp. That is just for starters and since I am replacing the motor I need new block drains and not sure what is the best to use. I also need to look at a diagram and order a couple other things. Thanks in advance.
badbowtie
Re: need part numbers for fuel line and more
That is great I don't think that is the one I used to use I would of thought I would of remebered that but it seems to cover everything.
