Need parts for 5.5 sea horse cd-17
bosco83
I'm repainting my new to me outboard and while I was taking it apart a couple of bolts broke off. They are like little rubber motor mounts they bolt the motor and shaft assembly to the part that clamps onto the boat. There are five total and I broke off two :rolleyes: I was expecting a few things to break while taking it apart so I just hope I can get some new ones. I also would like to replace all the rubber gaskets that go on the cowling. I can take pictures when I get home if needed.
Thanks,
Brian
Chinewalker
Re: Need parts for 5.5 sea horse cd-17
Hi Brian,
Which ones did you break? Of the five, there are two up top on the sides, one up top front and center, and two hidden inside the "horseshoe" at the base of the swivel bracket. I've got a mid-section that is disassembled, so I probably have all of them here...
- Scott
bosco83
I broke off on of the ones that has the two screws that holds it to the shaft/motor and the one up top in the middle that has two studs sticking out with two nuts holding it on. They all broke off clean on the nut side. I had to use an impact driver to get all the straight slot screws out but they all came out ok.
