Need picture of 1979 80HP Mariner
bucchb
Could someone post a photo of a 1979 80hp Mercury Mariner power head on the ignition side similar to the one I posted??
In particular I am trying to figure out where the Brown Tachometer wire attaches??
Also if you have one of these engines on a boat, What type of tach gage do you have??
Thanks and happy boating
Bill
Chris1956
Re: Need picture of 1979 80HP Mariner
Bill, The brown wire for the Tach needs to go on one of the rectifier AC terminals. Behind the switchbox in your photo, is a black square rectifier with three connections. Two are yellow wires from the stator, under the flywheel, the third is the red +12VDC charging wire. Connect the brown wire to either of the yellow stator wires. A conventional Outboard tach will work with your motor. Teleflex and Faria are two brands that are compatable.
