Need procedure for setting timing on OMC 4.3
mspencer
Hi. I need to set timing on 89 OMC 4.3, but not sure of the proper procedure. Can any one help with this? Thanks.
Mike
jfcar
Re: Need procedure for setting timing on OMC 4.3
Adjust idel speed to in-gear RPM (my 1991 4.3 OMC Cobra is 550-650 RPM), then shift into neutral. Set timing tighten clamp bolt recheck. My timing call for 6 degrees BTC with 89 octane or greater fuel, 0 degrees for anything less.
bruceb58
Have you checked your timing before?
Do you have and know how to use a timing light?
mspencer
Yes I have checked timing before. But all my experience is with older cars with vaccuum advance and wanted to make sure ther was nothing special I had to do because of being marine and no vacuum advance. Thanks again.
mike
bruceb58
Nothing special. There is no vacuum advance.
