Need prop advice
sqhurt
Have 89 vip 17 open bow, with the ford 2.3 and cobra outdrive. I bent the prop while backing up and numbers on the prop are h2-1317. Is there one better i could put on there or stay with that one? Thanks
Reinell-BRXL-191
Re: Need prop advice
The Turning Point Hustler props are good props... you could use just about any 13 1/4 x 17 pitch 3 blader, and probably not notice any difference.. If you are happy with the performance of that prop, you could go cheaper or just buy the same one...
