need prop replacing help//please
kbryant
Hi, I have a 1994 120hp Force Outboard. I am not sure if I need a speical tool to get the old prop off or do not use a wrench to take the nut off? Looks like something is covering the nut and not sure how that comes off? Any help would be great!!!! Thank you
jerryjerry05
Re: need prop replacing help//please
If it' just a nut? Sure a socket or cresent wrench.
If it's the mercury setup? Then a screwdriver and then a wrench.
Screwey to bend the tabs up.
Pics always help??
Profile?,Location? You might be close to someone who can help??
Frank Acampora
That uses (usually) a Mercury type locknut. The nut is seated inside a stainless washer. the washer has tabs which would be bent down into the grooves in the prop hub. You use a screwdriver to bend up the tabs so the washer can spin. Then use (I think a 1 1/8 inch wrench) to remove the nut and tab. The prop should slide off. If the shaft has never been greased, the prop may fight you.
kbryant
Thank you. Yes, it has the star like looking thing and the nut sits inside that. I will use a screwdriver and wrench. Thank you for the help!!!!
jerryjerry05
Just send a donation to the "Send Frank and Jerry to Australia fund" :)
