crystgryph
- Sep 20, 2005
- 3
Hi! Newbie boater here. Haven't done any boating since I was a kid (25 years ago!). I just got a 1957 Cadillac Coronado 14' Runabout (Aluminum ~ 625 lbs.) with a 1960 Evinrude Lark 40hp (Model #35520). Have no info on motor/RPM/gear ratio, etc. Prop on boat in bad shape, gouged, chipped and spins on shaft by hand while in gear, it is a three blade alum. 10-3/8x15 according to a guy my neighbor took it to, but he didn't think he could fix it without cracking the hub. He has one that is used, ~10 dia. with 14 pitch for $40, don't know if this prop would be right for the boat. Plan to use the boat for tubing my kids around, cruising and fishing (not trolling) on a small lake. I figure 1000 lbs. min and 1400 lbs. max loaded. No tach, don't know if speedometer even works yet. How would I be able to check RPM's? Would appreciate any information or direction.
