Hi Poolshark<br /> The prop nut, Part# 376501 is a dealer part. They don't list a size. There were three prop choices. #383629 9"X10"std.<br /> #379717 9"x9"<br /> #592959 9"x10" weedless.
thanks alcan did help....<br /><br />we have a couple af marine shops about an hour away..will check with them on that part no....<br /><br />i have a prop that was given to me that will fit (come off evinrude same year/hp) but dont know size or pitch...how do you tell??<br /><br />i have a 14' PolarCraft with a front deck that i extended ~2ft with 1/2" plyboard and a rear bench with a TohoRig(from cabela/bass pro) livewell..dont really care 200mph with hair on fire but dont want to be grandpa on a sunday poke around...i fish delta oxbows mainly..what size would you recommend...
left info out in last reply..<br /><br />rear bench and a tohorig livewell that is pretty well centered in boat...boat moves real good with a 36lbs thrust trolling motor..
Poolshark,<br />I would go with the 9" X 10" Prop, which is rated for a "Normal" load for your sized boat . This should put you in the ballpark as far as WOT RPM's.<br /><br />Does the Prop you have, have any numbers or letters on the hub??
not sure..will check on it tomarrow...<br /><br />do you preferr pin-drive or spline-drive props....i have a foot from a parts motor that have spline drive but prop is spun out...
