Need replacement prop
1stHound
93 25hp mariner 2 stroke, Bought 1st boat, prop has 1/2 in missing ding in one blade, confused on which to buy. total new boat guy. # on prop is
48 19640 A 40 13P Some come with new bushings some not. what would you guys suggest? I would like to purchase from iboats but not sure which one I should buy. Thanks very good site for a total newbie
steelespike
13"pitch is the key number. look up a Solas Amita and what ever kit is suggested.
Solas props have a good reputation.A prop selected for your motor will be the correct diameter
and configuration.
1stHound
Thanks Spike, now to find a missing nut and bolt on the arm that holds the motor in the up position, Not familiar with metric nuts and bolts, I need to find boat lingo so I can explain myself better.
steelespike
If you need to hold the motor up on the trailer you need a motor support for trailering.
If you can find a parts blowup it may give a part number.
Otherwise just get 3 or 4 that seem right at the hardware/Home depot etc. and return those that don't fit.
1stHound
Thanks steelespike, The small boat I purchased already has a motor support that was on it, But I may have forgotten as I was a little overwhelmed trying to remember all the stuff to look for before I bought it. I have been going through it slowly, Havent found much yet other than some loose screws, I did find a missing bolt on the motor that puts the lock lift in the up position, it is a manual lift and without that bolt for the lock cam to hook into I wont be able to come in without whacking a prop. bulbs on the trailer are fried so I suppose it was launched while still plugged in. (easy mess up) boat plug looks dry and cracked, didn't have time between storms to check lube in lower unit and plugs yet, Runs just fine in the barrel But yeah I am aware that a boat will be a never ending expense, But I love fishing so what the heck.
