Re: Need some advice and guidance, PLEASE
Hey JBC, how do you get those pics all nice and big like that???
By using photobucket & posting the IMG code
Thanks for asking.....
All that info about repair & replacement of rotten wood on a wooden boat will be very helpful info to have, so remember where you found it.
I'm sure it won't be a surprise, or at least it shouldn't be, but the more effort, time & money you spend NOW, the less you'll spend later, AND it will last a bit longer before you have to redo anything, including touching up the wood sealer you use.
New high end wooden boats might get 20 coats (or more) of hand rubbed varnish on ALL the exposed wood on the boat.
I don't know if it's appropriate for anything below the waterline, but you might as WoodOnGlass to post the old time boat finish based on boiled linseed oil. If you are only talking about the upper area of the hull in the pix you posted & the trim above the waterline, I suspect that the BLO finish would work pretty well, and be relatively inexpensive too. It would also not be detrimental to have used the BLO & later when it's time to redo or reapply, if you wish, you can probably use a spar varnish or urethane.
Your thread, and the info you'll need that's specific to wooden boats is one of the reasons I suggested a wooden &/or homebuilt section in the resto forum.
Here's a GREAT example of a wooden boat built by an iboats member:
New build crackerbox
Knowing that I wanted to some day build a wooden boat, I've read wooden boat magazine for years:
WoodenBoat Magazine | WoodenBoat, Small Boats ...
They have a book publishing division as well:
[h=3]
WoodenBoat Books - Home[/h]and there are a few on evil-bay
This book is available used for@$14 delivered on amazon:
Painting & Varnishing
Here's another, and it's table of contents:
Table of Contents:
Intro
Maintenance in the water
Winter Maintenance
Scraping down to bare wood
Surface treatment
To glue or not to glue
Wood for Boatbuilding
Screws and nails
Corrosion and nail sickness
Tools
Plugging and filling in smaller damages
Joints
Splining
Wood Frames
Steel frames
Floors
Planking
The backbone
Deck
Superstructure
Interior design
Mounting hardware
Masts
Engine installation
Purchasing a wooden boat
Drawings and specifications
I bolded the sections that might be relevant, looks like it's about 60% or more of the sections. Although you aren't to a restoration stage yet, or in need of removal & repair of rotted wood, keep this boat for more then a year or 2, and you may need most if not all of that info.
Amazon also has a
Repair & Maintenance book that might also prove helpful, for $12 shipped, but used.
After building the small knock-down plywood boat several years ago, I KNOW I'll build a more substantial boat 1 day. I may never have the skill or funds available to build one remotely close to Sean's
Old's Cool but I will.
LOTS of good info online, you might even find a digital copy of a book, that can be downloaded to an electronic device.
