Last July I bought a 2001 Crownline 205 br it has a new long block and when I took it out first time was still in the break in period after finishing the break in I was happy to finally open her up but to my dismay the boat had a really hard time getting on plane and would only run up to about 3100 rpms at wot so at the time I didn't know it should run at 4400 to 4800 at wot. It came with a 21 aluminum 3 blade so I thought if I went to a 19p 4 blade it would fix my problem well I was wrong. Still have the same problem today and since then I have found out that I needed new plugs and wires so changed them still no better I have the mecruiser 5.0 efi aND the boat weighs 3500 lbs dry. Now I am back to thinking that the prop pitch is too high the boat runs smooth as silk but takes an eternity to get on plane and then at wot still 3100 rpms and barely 30 mph trimmed out I am so frustrated any suggestions would be much appreciated
