Need some clarity on sterndrive, gimble and engine compatibility
skijunk
I have a 1998 Tracker Tahoe with 3.0 mercrusier (engine is bad) that I am doing a V6 upgrade on
The donor boat is a 1987 Citation mercrusier V6 170 with mercrusier outdrive
The question is, will the outdrive from the 1987 donor boat bolt up to the gimbal on the recipient 1998 boat? Man that would be awesome if it would.
Nope,.... Everything forward from the rear motor mounts will drop in, 'n go,....
From the rear motor mounts aft, is a different animal,....
The '87 is an Alpha 1,.... the '98 is an Alpha Gen.II,.....
skijunk
That's what I thought but was just making sure. Thanks !
wahlejim
Master Chief Petty Officer
check the drive ratio as well when switching to a bigger motor
skijunk
The donor boat ratio is 1.84 and the ratio of the leg in the Tahoe is a 1.94 so I will either need to get the whole 1.81 gen 2 unit or at the very least the top outdrive
