need some gearbox help now
mr roach
thanks for all the prop help now i have a new situation along with the new prop it was recommended i change the impeller & as it made perfect sense i went ahead & bought an impeller. Took the lower end off,changed impeller etc, attempted to reinstall it & went well until the last inch or so went to turn the prop so the shaft would line up & fall in place only thing is when i turn the prop the shaft does not turn. I went ahead & removed it & put it on the bench. When i turn the prop or shaft there is slight rotation of the opposite shaft but minimal contact by hand will stop the rotation but i can freely & easily the opposing shaft. Did i somehow disengage one shaft from the other or do i have a problem in my gearbox. I attempted to post this earlier & think i goof it up if did post it once already i apologize for the repost. All your help is greatly appreciated
Re: need some gearbox help now
Ayuh,... This is the Prop forum,...
You need to post this in the forum for WHATEVER motor you're talkin' about...
mr roach
sorry new to this type of website & am still trying to figyre it out started off with prop problems & this is connect to that problem & has to do with the fact that when i turn the prop my shaft does'nt rotate. Will try the engine section thanks
