Hi their,
i just traded my dirt bike for a 1996 14' nautica ridged hull inflatable with a 90 horse power mercury sport jet.
when buying it i had the seller meet at a dock and i took it for about a 5 minute rip. it seemed to run ok and idled.
about an hour later i took it to a lake and it woudnt sart? their was gas dripping from the carbs so i set it wide oped and turned it over till she started.. once out on the lake it toped out at about 28mph eventually it cleared up and was cruising at 35mph.. once i put it in neutral or trolling speed after about 2 minutes the motor died... got it started after about 5 starts and took off again.. after taking it out a few times and dealing with these problems it seems to be harder and harder to start the boat. last time i tried to launch the boat it wouldn't even start.
THINGS IVE TRIED:
*PULLED THE CARBS OFF AND CLEANED THEM OUT
*PUT SEAFOAM IN THE TANK --- (but havent had the engine running enough for its effect to take) place
* SLIGHTLY ADJUSTED THE FLOTE LEVEL TO HOLD LESS FUEL --- (BECAUSE THE CARBS WHERE FLOODING)
ONE THING I NOTICED: I JUST PULLED THE CARBS OFF AND SPRAYED FUEL DIRECTLY IN THE ENGINE AND IT STARTED RIGHT UP !! SO IM GUESSING THE PROBLEM IS ( CARBURATOR ) AIR FUEL ?
ANY HELP IS MUCH APPRECIATED IM EXTREMELY LOW ON FUNDS AND JUST WANT TO GET THIS RUNNING BY THE WEEKEND FOR CAMPING !
thanks!
THINGS IVE TRIED:
thanks!
