Hello I have a Chaparral 240 signature with a 5.7 300-b engine. My tilt and trim went out last weekend I was able to run jump wires from battery directly to trim pump and get motor to get home I have checked the 10a fuse on the pump not blown changed both relays on pump still no go found the fuse block on the engine and found a blade fuse listed as CB on scematic which I assume is for circuit Breaker. I have removed it as it is a manual reset breaker and does not seem to want to reset Problem I cant find any info on this blade circuit breaker I'm going to include photos of it can some one tell me a good part number and where I may be able to locate thanks for your help in advance.
