Need some help finding breakers or fuses on 2006 harris grand heritage
toolman4
Does anyone know where the breakers or fuses are that control the radio and interior lighting. The speedo, tach, and voltmeter work, and the boat runs.
toolman4
The main power wire goes to this distributer type thing . Does someone know what this is and does? Maybe a solenoid?
those fuses should be at the helm, either in a fuse box, next to the switches or some place close. if it has a soft-switch panel, they could be polyfuses (electronic self-reseting fuses)
that is a power contactor in the picture (also called a solenoid)
toolman4
Its just crazy to me that none of these inline fuses protected anything....on that rectifier harness and before the 1,2 off selector switch. There is no fuse panel anywhere under the helm or in the vicinity that I can find. It does have a power management system under the helm. Is there breakers associated with that? Everything worked before the rectifier harness was fixed. But that rectifier was putting out 16 volts before this happened. Any way to get a wiring schematic for that boat?
