After taking the boat to the lake yesterday, I found my choke did not seem to be working, everything else was running great, but when starting it cold, it was a real pain to keep running. It would not idle until I got it warmed up to 170 on the trailer, or it would die. Once It got warm, it was fine then it idled no problem, but until then it cut off when I tried to put it in gear. It also did this one time when I was leaving a beach after sitting for about 1.5 hours.
I have the electric choke, and I took a look at it today, it seems the choke is not working at all. I read through the Edelbrock Manual on this and can't figure out how the choke it supposed to get triggered to close. Can anyone help me on this? I put the Throttle all the way to WOT, and pumped it a few times. Then turned the key to the ON position, did not try to crank it, just put it in the on position, thinking the choke should be triggered but it was not. This is what I am not sure about. The positive wire is hooked up and it has a good ground on the Ground wire.
Also I noticed that the Fast IDle screw which is A in this picture is not on my carb, so I will have to replace this.
Bryan
Bryan
