need some help
tintug
I have a couple questions. First I cant find my thread that i had started on my restore. Is there anywhere I can go look for it to continue on with it? Or start a new one? Next is I'm putting the transom and the splash pan back in and there is a few small holes in the outside of the transom from unused screws. most of them are small with 3 of them being about 1/4" from the old swim platform. What would be the best way to seal these up. I thought about putting scewrs back in them with some 5200 on them.....or using some J B weld to seal the up but not sure how that will hole up in the water.
83mulligan
Re: need some help
Hey Tintug. Click on your name in the upper left of your post. There is an option to show all posts you've made. This should help you find your thread! Hope this helps. Hey, you aren't too far from me. I'm up in michigan.
andgott
Master Chief Petty Officer
Re: need some help
Refill the holes with thickened epoxy- Don't take a chance with screws and 5200... They PROBABLY won't ever leak, but epoxy will seal it all off and make SURE water doesn't get in there.
