Re: need some pointers/help please
Yup,
it will take a while of tunes and no motor running - if you just have a simple radio and a good battery, or it will take no time at all with a big radio or a bad battery.
basically, radios take amperage (small ones 2 to 5 amps, big ones up to hundreds of amps) the standard auto/marine battery has 70-100 Amp hours (i.e. 2 amps run for 1 hour = 2 amp hours) so you have a lot of time. Motors take a lot of power (100-400 Amps, yours on the 100 amp side) to start, but usually don't take to long to start.
When you are running the motor, it charges the battery, so it is a non issue.
You might just want to get a rope to pull start your 50... but check it out first if you can do it.
Or you might want to buy a "Jumper box"
Or you could just put a spare battery into another compartment in and a set of jumper cables...
Or wire in a more complex multi-battery switch.
all will work, just depends on what you want to accomplish, and how complex you want to be.
if the motor starts over really easily the rope may be easiest.
Don't skimp on a staring battery... it sucks to be stuck floating , waiting for someone to float by...
regardless if you have a single battery system, best to re-charge when off of the lake and disconnect or use a switch to 'turn off' the battery.
Welcome to the boating world...
