Hello Again........ I've been thinking alot about the transom on my boat, I wasn't going to replace it, but I think it's bad enough that I should, especially before I paint it and get everythng back together. I've been looking around and can't find a good step by step explanation on how to replace it(not the seacast method, due to the cost). Could someone outline the steps? Also what exactly is epoxy, I have seen that you are supposed cover everything with it, is it the same as fibergass resin? And where do I find it, and how much will it cost, all I can find is the resin and it's about $12 a quart? Thanks again!!!
