Wingnutt
- Jul 16, 2003
- 255
I've got an '89 Regal with a Merc 4.3 in it, when I was winterizing it this weekend, I noticed that the thermostat was stuck open. OK, no problem, called the local parts house and ordered the thermostat, and gaskets. I took the thermostat housing apart Sunday and picked up the replacement thermostat and gaskets today. Now here's the problem, I went brain-dead and can't remember which gasket went where. One gasket has two little circlular inserts (brass?) on each side between the bolt hole and the large hole for the thermostat. Does this gasket go on the cover or does it go between the housing and intake manifold? Everything is at a stand-still until I get this sorted out. TIA
