Need to add/purge trim fluid 150 ocean pro
crazy charlie
Havnt done this in a while.Sounds like i may be a little low or there is some air in unit while lifting motor.Down sounds fine.Begin with motor up,unscrew fill and put fluid in ,run motor down and back up and refill.Repeat several times,screw fill back in and done?? Sounds right?? 1995 150 ocean pro
Chris1956
Yes sounds right. Let her sit a minute or so to allow the air to bubble up to top of reservoir. Try to get motor reservoir level as well.
