I have recentlly relocated in Savannah, Ga adn had to find a mechanic and decided to try a local guy here that has his own repair businest. His prices are half of what he normal marine shops charge so......
I have a 1987 45HP Mercury. I was running good then gradually starting running slower and slower and I had excessive gas use, with fuel coming out of the top of the top carb. The WOT speed was approximately 6mph(Handheld GPS) and 2400 RPMS on tach. In the yard on the muff it would run fine with a small miss but nothing that was bad. Sometimes it was hard to start but always did eventually start. I chalked this up to the carbs needing to be rebuilt.
I finally was able to get the boat to the new mechanic to have the carbs rebuilt. He rebuilt the carbs and check the compression and the spark. He states that the compression and the spark are good but he states that cylinder #1 and #2 are dropping and he is thinking it is the switch box. He has not put it in the water only put it on the muffs.
I guess the question I have is this correct? Or could he be correct? Other than the excessive fuel adn the low RPM's at WOT I have had no issues and the motor has been runnign good. The stator was replaced about 9 months ago with a brand new one, so I am assuming that should be still good but I do know with electrical stuff you never know.
Anyone have any ideas on this? Being my mechanic is new to me. I am just not sure if I trust him yet or not. I don't want smoke blown up my butt for no reason but if what he said is true then I guess I can trust him.
Would appreciate any comments on this thanks.
