vroom ZOOM
- Aug 15, 2017
- 427
Hello
Got a couple of questions. My boat is a 2010 lund 1725 explorer ss with a 2008 optimax 115.
First, I think I am overpropped. WOT rpm spec is 5000 - 5750 rpm on that motor. My current prop is a michigan wheel aluminum 13x21 and at WOT and light load I get 75 km/h at 5200 rpm. Little too low IMO. So I can go down to a 13x19, will that do the trick? Also will staying with a 13x21 and going stainless do the same thing? IMO its a pretty fast boat right now lol.
Second thing is that I think I have an issue with the engine height. I can't go past 1/4 trim on the gauge without over revving and losing lots of speed. If I trim past 1/4 from full down the prop loses all grip and the boat drastically slows down. The way I have been driving it right now is I trim full down and then get out of the hole. It has a little bit of bow steer but not really noticeable. Then I start trimming up, and the boat starts going a lot faster and the engine starts spinning faster. When I get into the readable range on the trim gauge, I an pretty sure it starts ventilating, but still if I trim up more the boat goes faster. If I take a look back the prop wash is shooting out of the water kind of in a very low rooster tail (maybe 1ft tall at its highest point) but still no loss in speed or crazy rpms. If I trim farther up it will rev to the moon but I am only 1/4 way up! Now here is another weird thing. If I start to turn in this highest position, it will ventilate and loose all grip, so before I turn I have to trim down (this is where the trim down bow steer starts getting noticeable). So yeah I think this rig needs some tweaking. I bought my current prop brand new, and after a few times out one of the blades has a cavitation burn mark already. So maybe I should leave the engine where it is and get some sorta surfacing prop? Will putting the motor down one hole help with these problems, or should I just get a smaller prop and run it the way it is? What is your ideas on this?
