Need to know fuel:oil ratio for evinrude
acdc96
I just bought a 1942 Evinrude Sportsman 2hp today. It's in great condition and run perfectly. I don't know what fuel oil ratio it needs? I know my 1938 Neptune has a 16:1 ratio. I also bought lead substitute additive to make up for no lead in the fuel.
F_R
From the Evinrude Service Manual, Fifth Edition: 1925-1951 Sportsman 1/3 pint per gallon (24:1)
You don't need that Lead. Leaded fuel actually was detrimental to outboards. Having said that, I don't know what the "substitute" is. But I don't think you need it.
nwcove
+ 1.....forget about the lead additive for your ob....it may have a benefit being used in a model A ford, but not so much in your vintage two stroke. jmo
acdc96
I've heard mixed opinions about adding lead or lead substitute to the fuel. I wouldn't put real lead in any engine due to the toxicity. I just do it because of more lubrication.
Vic.S
There are two main reasons for gasoline to contain lead additives or substitutes. Neither is applicable to 2 strokes One is to raise the antiknock index for high compression engines .... 2 strokes do not have high compression ratios! The second is to act as a valve seat lubricant ....... 2 strokes do not have valves!
Vic.S
sorry about the layout and punctuation of the above. Cant get at it to edit it either Posting on these forums seems to be getting more and more difficult !
That was in the 1960's and early 1970's for " white gas " I believe.
F_R
Yep, people went out of their way to find gas without lead. All lead does in a two-stroke is make hard carbon deposits.
