Re: Need to know value quick! 1983 Chrysler 90hp
I forgot to mention: 120 on all cylinders is a little low, Factory new was about 140, but compression results are dependent upon the gauge. As long as they are fairly equal and relatively high--not 20-60 PSI-- then the engine is probably healthy. AND, with some continuous running to deposit more oil in it, results may come up a bit.
The single lever, behind the upholstery control was nice and simple looking and took up less room than the surface mount control box--I always preferred them. HOWEVER: if it is that important to you, you can find a US Marine/Force control box on the auctions. Some of these boxes have the tilt switch built into the hand grip of the control handle--very handy as you can adjust trim with just a thumb movement. These boxes also have the ign switch built into them. And you should be able to use your existing ignition switch IF it is a six terminal, push to choke switch.
