Need to replace ball joint assembly, help with part.
YeahBuoy
hello everyone,
the small plastic ball joint assembly broke in my 1989 omc.
this is the parts diagram and the part I'm taking about is #3 on the diagram, part number 0379926.
http://www.**********/parts/search/...MEF/INTAKE MANIFOLD & FUEL SYSTEM/parts.html
now it seems the part is "obsolete." does this mean that there is a better part out there I should use? or should I just buy the obsolete plastic bit
thanks in advance!
Tnstratofam
Re: Need to replace ball joint assembly, help with part.
Obsolete usually means no longer available. You will probably have to find someone who makes a replacement part, or find something that will work in its place.
bruceb58
YeahBuoy
Yes that's exactly what I bought. thanks Bruce :D
