Need to seal L/U exhaust divider?
Status
Not open for further replies.
P51D
I have a '91 or '92 Mercury V-6 175 HP 2.5 litre. Serial #OD223009. Don't know its maintenance history, so among other things, I put in a new water pump kit. I had only a SELOC manual at the time, and was getting advice from someone who I think knows what he's doing (he's been in the O/B repair biz for over 20 yrs). <br /><br />After removing the lower unit (L/U), I noticed that there was silicone sealer on the divider between the water pump cavity and the exhaust passage. I was advised that it wasn't needed, and I didn't see it being called for in the SELOC manual. So I removed the old sealer, and I didn't put any new sealer on the divider. I've put the L/U back on and have run it on muffs only. <br /><br />I've since obtained the Merc Svc Manual, which DOES say to put a bead of sealer on the divider. I've seen at least one post on iboats saying it is not needed, others saying to seal it. So now I'm wrestling with whether or not I should drop the L/U again and seal it. :confused: <br /><br />1) What are the consequences, if any, if I don't seal it?<br /><br />2) Has anyone else not sealed it, and were there any problems? Or did you notice anything unusual the next time you had the L/U off?.<br /><br />Any advice or comments very much appreciated!
heybaylor
Re: Need to seal L/U exhaust divider?
waterpump housing can get very hot without the sealer...mine cooked the alignment tube "plastic"..<br />I put it on from that experience..<br />just a bead across the waterpump cavity will do
P51D
Thanks, heybaylor.<br /><br />Will any good brand name silicone sealer do, or do I need to track down what the svc manual recommends (GM Silicone Sealer 92-916000-1)? That is, do I need a special high temp sealer?<br /><br />Any and all comments appreciated. Outboards are new to me. Always been an inboard guy, but I'm actually having fun learning about O/Bs!
Laddies
Banned
I have always used the gold colored RTV sealant when in doubt, it's good in heat, oil, and almost anything
clove
The marina that changed my water pump in my '89 135 Black Max used a white marine sealant. The bead was about 3/16" thick before he assembled it.
P51D
Done. I used a Permatex high-temp silicone sealant. THANKS for the advice!
dmoriarty51
I know this is an ancient post BUT. If a person was to not use sealant on that area could it cause an abnormal pee stream by possibly allowing exhaust gases to be pulled through the water pump and aerate your cooling water?
GA_Boater
12 years old. No buts, start a new thread.
Closed.
Status
