need tools
reeldutch
were can i find a flywheel holding tool online?<br />and a ring expender/compressor. OMC.<br />is there a good side to find tools, because i would lik to have my own tools.
Dhadley
Re: need tools
Contact Precision Manufacturing at 800-237-5947.<br /><br />Good luck!
rodbolt
Re: need tools
hello<br /> the best flywheel holding tool I have found so far is a snap on model. cost about 70 dollars. the ring compressor I use is also a blue point. it has a pair of plier like handles and 6 rings the kit has a range of about 2.25" to about 6.5". works well with two stroke pistons cause I can wriggle it and feel if I am crushing a ring locating pin. I usually recommend staying away from the round ratcheting automotive type of compressors.<br /> Good luck and keep posting
Hooty
Re: need tools
I use a hose clamp for a ring compressor.<br /><br />c/6<br />Hooty
