Need transducer for Faria gauge
kaw550
Replacement Transducer or plug
Found the boat was taking in water last week. I couldn't find the leak until I put water in the hull. It was leaking from the transducer. I assumed it needed to be reinstalled with sealant.
When I went to do the work I found it was actually cracked.
I REALLY need it for the weekend.
Anyone know if a 2" plug/ fitting I can use to seal the hole until I can get a tranducer?
kaw550
My thru hull transducer is cracked and letting in water.
I am trying to find one asap. Are they specific to the gauge?
it is a 2006 Faria gauge. Will any 2" thru hull transducer work? Will it need to be specific to Faria and a specific model.
yes, to question 1
nope to question 2
answer to question 3 - you need a specific transducer for the faria gauge.
you dont NEED it, you want it for the weekend.
get a replacment transducer (you may need to get a new gauge).
or smeer it full of 5200, then when you get the replacement, swear up and down that you have to cut it out.
kaw550
Thanks. I am going to call the manufacturer tomorrow. I can't make out the numbers on the tag.
