I have an '84 Mercury 90Hp Inline 6 cyl. There is no spark on cylinders 1,3,5 (they all run off the same switch box). I have switched the switch boxes around and that didn't change anything, thus ruling out a bad switch box. I tested the trigger and that passed. I also ran tests on the stator, when I went between red & ground and red/wht and ground, I got the proper reading. When I went between the red & blue and red/wht & blu/wht, I got no reading at all (open cucuit). Is it possible the stator is bad? <br /><br />Thanks in advance for any help
