See below for a better explanation.........but I am looking for a good mechanical / fiberglass repair business in Michigan. (I would prefer Northern Michigan....but I will travel).......
I have a 1994 Four Winns Sundowner 235........it has the Volvo out drive.
When I first launched it this year (before I removed it from the trailer) I opened the engine compartment to check for water. I could here gurgling noises and eventually saw water coming in under the engine. I then brought it to a repair shop to fix. After 3 weeks they said the boot(s) were ok and that the leak was coming from the linkage tube (they said the linkage runs thru a tube and the tube is cracked).....so they said they had to pull the engine and it would be about 300-400 to repair. I said for them to proceed. After a few more days they said that they are pretty sure its not the tube but its leaking from a rotten transom around the tube?
They said they didn't remove the outdrive or engine but found someone skinny enough to get a better look. The repair shop owner told me that they could probably temporarily fix the problem and that I can use it for the summer and then drop off to them in the fall to repair it. (2000-3000).
Before I bought the boat last fall I had a mechanic and a surveyor look at the boat. They both said it was solid and had no flex (transom)...the surveyor said he had slightly elevated readings in certain areas of the transom but said its unreliable in that area due to all of the metal in the area.
Any advise?.......(it looks like they caulked around the outdrive housing and when I launched it yesterday it had no leaking (or very little) how would caulking the outdrive stop a leak at the linkage tubing?
I am in Northern Michigan and just need someone trustworthy to look and the problem and complete the repair properly (whatever it is)
