Hello All,<br /><br />I Want to install a 8-HP kicker motor on my fishing boat it is a long shaft 22.5 inches, but if I install it on the place where it should be on the transom the cavitation plate is above the bottom line of the hull, the propeller is in line with the bottom, so if I use it only for trolling do you see any problem if only the prop shaft is in line with bottom ? I don't want to buy a bracket and drill more holes in transom.<br /><br />Thanks<br /><br />Smoky
