needed: furuno GPA 016 antenna cable
Alws55
This antenna has a connection that looks like a cable coax connector, and also uses a coax cable by the looks of the male connections , don't know the specs of the cable . The connector is a TNC OD looks like 7/16". I'd like to find the right components and put one together, haven't found anything online thsts OEM.
furuno
GP-1610C
GPS/Plotter
Alws55
Re: needed: furuno GPA 016 antenna cable
Yes...waiting on reply.
Alws55
I see I need 2 TNC-P-3 connectors and the TNC-PS-3D-15 is this the cable required? Can you suggest what I can use or something similar that will work.
Thanks for the help!
dingbat
Coax is coax for the most part. RG6 would work, but I would use a white RG11 for it's robust construction and its better UV resistance.
Alws55
I used a piece of cable tv coax without connectors it worked. I took the specs on the connectors and emailed some retailers on ebay and found them quick, bought 3 for $9.00
Thanks for the links Admiral!
