My OMC service manual DOES NOT show a ballast resistor in line. If my voltage on my ignition wire at the coil reads 12V I must install the new ballast resistor correct? If it reads 9V there must already be one installed in the line? Is this the correct test to let me know about the ballast resistance. My new coil does not have built in resistor.
New coil-
http://performanceparts.com/part.php?partID=48407
Thanks so much for the help. Ed
