redneck joe
- Mar 18, 2009
- 12,138
Mostly.
1984 75 Rude.
Had a flat spot getting on plane early last season - i could feather thru it but got to the point where I had to kick the choke to get going. Had the criminals that operate the boat shop I used to give money to for carb rebuilds. Ran great rest of the season. Same thing mid season this year, getting worse. Runs fine when starting fro cold, pops up on plane, RPM's sound OK maybe a bit low (no tach). Then when I stop to chill for a minute it really doesn't want to get on plane and I have to hit the choke to keep it running at any decent rpm. Runs fine at idle - all 8 miles back yesterday. Oh and the 1971 6hp kicked on second pull and ran beautifully for a couple miles.
Interestingly when I got back to the ramp, which has a very small dock, there was a pontoon just sitting there. I waited for about 10 minutes a ways off thinking the truck would be pulling the trailer down shortly. Started to get pissed. Then as I drifted closer I saw the cowl off. Yep, broke down. Pulled up and started talking to them and turn out he was having the same issue on his Johnson 3 cyl. Forgot to ask the year.
So, thoughts? I did run a crap ton of seafoam thru it (yes bruce the snake oil) and the cold start / on plane is much better but the hot issue is same or worse.
1984 75 Rude.
