Needs parts for DT90 carburetors...help need back on water
bansil
My new to me motor would not idle Suzuki DT90, I took carbs apart and found several issues
Ethanol sucks to start with, mounting gasket was missing a big pc, it was actually under carbs on engine pan, you can see how the broken gasket was actually re-torqued down clamping it with part of gasket covering butterfly valve (there are no pcs inside engine either)
also one of the highspeed nozzles was broke off and just hanging out in float bowl
I need:
2 mounting gaskets
2 float bowl gaskets
1 highspeed nozzle
For a mikuni BW36-24x2 carburator (numbers on carb are 87 E10 with an 8 over a Y 1 and the throttle plates have a 38 and then a square w/65 beside it)
TIA
Can anyone help? With a place to get parts???
bansil
Sweet link, got parts in today.
hope to be on water Sunday
thank you
bansil
Okay, iwas told the green crystals were from that, just water in the carbs?
