So I know there are a million threads about wiring a dual battery switch. I searched a bunch for info before I decided to post my question. Just a quick background. I am in the process of rigging a small 16' skiff. I purchased a perko dual battery switch, have 2 deep cycles (which are not the same group size!), my outboard has remote start and steering and I plan on running a 12v trolling motor and a handful of low draw accessories.
My game plan is to have everything hooked up to the common. I figure I can select one battery or the other to operate all the accessories on the boat. And in an emergency situation I can elect to run off both batteries. I realize that in order to be able to start the motor off both batteries the outboard must be grounded to both. I have seen where guys run a jumper from 1 neg to the other neg. But then I read that this is improper unless you bump up the gauge of the cable to the outboard. Is this true? I have seen where people run a dedicated neg from each battery to the outboard. But what about the accessories? I need to make sure that they are all grounded to both batteries too. So do I run a cable from each battery to a bus bar? Finally, would I have any issues running on the "all" setting with 2 different sized batteries?
I figure I want to do this correct, the first time. Any info would be greatly appreciated!
