fishin musician
- Feb 16, 2002
- 1
I recently became the caretaker of a 1974 115 Johnson. The engine was running when the boat was left unused for nearly two years. I pulled the plugs and had a hard time turning the flywheel by hand. Motor was tilted up and I lubricated the cylinders with wd40 and then oil and let sit. Motor now turns easily without plugs in but is difficult to crank when plugs installed. There does not seem to be any corrosion or other signs of engine seizure. Thoughts?
