I purchased a Mercury 30 ELHPT 4 stroke outboard in 2017. While changing the oil filter I usually stuff couple of paper towels below the filter into the bottom of the cowl. This absorbs any small oil that may occur during the procedure. I gently removed the paper with long reach needle nose pliers. In doing so I also pulled up a small hose from the bottom of the cowl.
The other end of the hose disappeared upward into who knows where. I spent some time trying to find a nipple to re-attach the small hose end to. I could not see or feel any. What I did see was a tiny hole in the bottom of the cowl – at the lowest point. I concluded that possibly the lower end of the hose was snaked in there and designed to lie loose in the cowl bottom to drain “something” from up above.
Is this correct? Or do I need to worry?
