neutral? forward? reverse? lower unit '79 115hp
rednight
Hi:<br /><br />I just removed the lower unit on my '79 115hp, and think my shift lever may have moved on the way down. It was very corroded and a difficult remove. <br /><br />When I turn the crankshaft clockwise, the propeller shaft turns clockwise, too. I'm guessing I've bumped it out of neutral. My questions.<br /><br />1) Am I in forward or reverse?<br /><br />2) If I move the shift linkage, how do I know I'm in dead neutral? <br /><br />Thanks for any help. This is my first question, but I've been reading the board for ages, and every other question I've ever had has been answered. Thanks!
Backlash
Re: neutral? forward? reverse? lower unit '79 115hp
Hi Rednight,<br />You're in forward. If the prop were turning counter-clockwise you'd be in reverse. When in neutral, you can turn the prop in either direction.<br />Backlash
rednight
Thanks so much. That clears up a lot. I assume by "turn either direction," you mean without turning the crank shaft. <br /><br />Thanks again.
Backlash
right....without turning the crankshaft.<br />Backlash
