Neutral Lockout Problem
njmedic3306
I just picked up a 1983 SeaRay with a Mercruiser 5.0 and Alpha I. I took the boat out for the first time and when I put it in drive it would stall. Sometimes I would have to shift back and forth until it would start. Then when it does start and I get it in gear w/o stalling it will run for about 10 minutes then just shut off. It feels like it's electrical not a fuel issue.
So my questions is does this sound like the neutral lockout rocker switch on top of the motor? I see a bunch on ebay for different prices how do I know which on to buy? Also are they hard to install and can it be done at the dock?
Thanks for any help.....
boatguya1
Re: Neutral Lockout Problem
Sounds like lower shift cable going bad and causing shift interupt switch to stall motor.
Ayuh,.... Agreed,... the switch is workin' just Fine....
njmedic3306
How can I tell if it's the switch or the shift cable? The only reason I am suspect is the motor is just shutting off every 10-15 minutes and I am not having problems getting it out of gear.
