Neutral safety
Roach12
I’ve had problems starting my boat in neutral so I took apart the control box and found this style of neutral safety. It has two white wires connected to it that come from the ignition switch. How do I bypass this?
GA_Boater
Bypass it to test and if the motor works, replace it for your safety.
scoflaw
Ensign
Deleted mine. If you accidently shut a Bravo off while in gear, you can damage stuff trying to muscle it into neutral.
