Neutral stall
Mowczarek
Just recently when I start my engine it will start up and then stall out. I can throttle up in neutral and it will start and run fine at higher Rpm. After 15 minutes I can put it into regular neutral and it will run fine. I replaced IAC today and still having same issue. Any suggestions would be great
First, welcome aboard
Second... It would really help if we know what you are working on. We do not read minds
Ayuh,....... Welcome Aboard,....... 'n just what motor would that be,..??..??
